Urgent Help needed Please.......
7 Nov 2007
Hi
I'm just in the process of putting my new PC together (I've built the last 3 I've had) But i've got a bit of a problem. The Asus P5K SE board i've fitted has got a 24-pin EATXPWR connector & a 4-pin EATX12 connector but the biggest connector on my psu is only 20-pin (its a OCZ StealthXStream 600w Silent SLI Ready ATX2 by the way) + there's a 4-pin plug tied to the cables supplying the 20-pin one. theres also two othe 4-pin plugs marked cpu-1 & cpu-2 should I be using these as there's only the one 4-pin connector on the board (just below the cpu) I bought this gear from OcUK by the way
Thanks in advance
