- 9 Jun 2009
Okay to cut a huge story short, i installed windows xp alongside windows 7, so windows 7 was in first, then i installed xp next to it. I lost the boot manager with windows 7 so only XP loaded up, i didn't mind this because i could still get to the windows 7 files, and i wanted to use XP.
I then tried to repair windows 7, so the boot manager worked properly, so i could choose.
This didnt work, and when ever i turned on the pc, it said bootmanger isnt installed press ctrl alt del to restart. so i installed xp on 1 of the 2 partitions, and now I have the original XP, and the 10 minute old XP. This is my problem tho...
It automatically boots into the new Xp, and can i change it or make it give me a choice? I really need to get on it tonight, and any replies are really appreciated.
i hope there is some software that will do it, or even better an option on xp.
Kind Regards, Dan
Kind Regards, Dan
