- 18 Mar 2008
Right, I've got a problem
In Turkey, using a european plug and half of my converter has gotten stuck in the plug hole
I can't just pull it out, as I'll get a shock
So, I'm assuming that if I use some sort of insulator to pull it out, It'd be okay? Will plastic work?
