- 9 Jun 2009
Hey, at my grandads, just installed a new motherboard, cooler and graphics card...
Fitted it all in, went to start it up, and it powers for like half a second so the fans just started to turn on, and then it turns off.
I took everything out keeping barebone stuff in, still didn't work, pulled out all the connections for the power reset LED's etc, apart from the power and it worked. So i put the computer on the floor, went to connect it to the monitor, tried to turn it on again, and the same old thing happened.
Dont know what to do... Any suggestions?
Spec:
Gigabyte
M52l-S3P
Phenom X4
4gb DDR2 Ram
ATI 5770
Artic Cooling Freezer 64 LP
Thanks in advanced
Spec:
Gigabyte
M52l-S3P
Phenom X4
4gb DDR2 Ram
ATI 5770
Thanks in advanced
