URGENT Help needed
22 Mar 2014
Plymouth
Hi there I just wanted to clean my computer today and I notice oil like spots on my gpu again . I think it may be corsair h100i leaking but I inspected it and this doesn't seems to be a case it isn't wet anywhere or oily. My gpu is working fine but I'm just worried.
Here it's a pic from around 2 months ago. Also is it safe to clean it with isopropyl alcohol wipe as it's oily.
These are pictures from today
I dont know what to do, I checked again and I dont see any oil coming from h100i. Can you help me please?
I'd stick some paper on there and just check it every day or so (if possible). It should be fairly clear whether or not something has dripped onto it.
I'm not sure about the ball bearing from fans. It may be it. Also is it safe to put paper towel on my gpu for few days (4-8 day while I use my computer for gaming to check). Also is there anyway I can clean off this oil spots?
I will take h100i from my case and inspect it further in a minute.
I'd put a piece of kitchen roll over your gpu and run the system for a day and see if you notice any drops on it.
Kitchen towel, your GPU will be fine, and also weigh it down with some pound coins to stop it floating around!
I had this years ago with my 8800 GTX's in sli, top card had 'oily' splodges on it, water from the CPU block was slowly leaking past the barbs (too much pressure) and then falling down the pipe then dropping onto GPU. The reason for the oily texture is it's likely none conductive stuff which has a nasty residue.
In the first pic, there looks like there is something between the ATX 24 pin connector and the ram module.
Also, if it is dripping from the cooler, how does it get all the way over to the left side of the GPU which isn't near the cooler or pipe work? :S
Looks like something on the PCB which is highlighted by the way the dust has settled, seems a very random spread if it was your cooler dripping on it.
Looks like the **** has really hit the fan! Sorry couldn't resist that one. ;)
I feel sorry for you any thing that goes wrong with a computer is always a worry.
