Sorry to bother you but i need a little help please.
I purchased the 6 x Splitty 4's and 2 x Farbwerk 360's also a Hubby 7 usb, also i got hold of an almost new Aquaero 6 pro with red heat sink.
I have fitted all these items in the back of my Corsair 1000D to power/control 21 Corsair LL fans (16 led's per fan) case shown in the inc pics i have sent you above, but i have come to the connection stage and its not as easy as it was with my previous non rgb fan build on the Aquaero 5 controller (5 fans on 1 splitter repeated to all the pwm headers)
I am a little lost here and wonder if you can help in the connection of the items what goes where and into what item.
Also, do i have enough Parts ie Hubby 7/Farbwerk 360/Splitty 4's to do the job, or will i need more.
EK Quantum FLT 360 res ( 3 pin D-RGB connector) 21 led's
EK Quantum Velocity cpu block (D-RGB connector) 17 led's
EK Quantum Vector Trinity RTX 3090 Gpu block (D-RGB connector) 12 led's
EK Quantum flow indicator DRG-B ( 2 led's)
All standard 3 pin D-RGB connection.
And i have a couple of EK loop DRG-B dual/triple splitter cables.
Finally, as i am no longer using Corsair Icue/hardware, my Corsair 1000D case has a proprietary Corsair 3pin front panel/power lead coming from the front of the case and connected to the commander pro, how or where do i connect this to the above Aquacomputer parts (inc pic).
Help Greatly app.
Regards
Michael
Help Greatly app.
Regards
Michael
