PC froze and so I pressed restart on the side and now it wont boot, the computer turns on and nothing shows, light on the monitor just blinks. I've tried taking components out and cleaning them, swapping and changing ram, removing the battery, moving the jumpers to reset the bios, I can't think of anything else.
I've got an epox 8rda+ and the error code it's giving is 'CF', the manual doesn't give much away as to what that means so im pretty stuck on what to do.
Thanks in advance.
Chris
Thanks in advance.
Chris
