URGENT Help Please - LCD Screen - Heat sensors
24 Jun 2007
Hi, sorry for the urgent but kinda is as wanna play with my new pc lol
I Have a new tower with LCD Screen to monitor the temp of
Graphics card
CPU
HDD
Fan Speed
Where do the sensors go? how do i keep them in place etc
whats best place for them as never used one of these before i dont want to put it somewhere where it might break something.
No manual came with it, and the supplier has not replied to my email
Thanks in advane for any help
For the CPU and graphics temps, just insert the sensor into one of the fins of the heatsink. Gives you a reasonably accurate reading. That's how mine are on my P160.
As for the HDD, You could try using tape to stick it to the actual drive. Should work OK like that.
Thanks
Hi,
Thanks for reply, What are good and bad temeperature ranges? before and after overclocking?? if anyone knows let me know
Thanks for help appreciates
