Urgent help please (shutdowns)
31 Oct 2006
Just installed the NTo6 lite in my sugo with an e4300 at stock. My system worked completely fine with the stock cooler however after i installed the new one the pc just crashes and turns off just as its about to go into windows desktop.
Everythings at fail safe defaults etc but no luck still. I can get into the bios and all seems fine. The cpu temp is at around 49-52C.
I am assuming the cooler is not working properly as it seems to me that the only reason for the shutdown is the cpu overheating.The cooler looked well seated on the chip tho and I used a pea sized blob of the silver thermal stuff and spread it out evenly with a piece of card.
Anyone know what it could be before I try to re seat the cooler or put the stock one back! grrr
thanks
ok just put back the stock cooler and now all is fine.
How the hell can this be? I thought the nt06 would be much better!! wtf!!!
waste of 30 quid and waste of a day
