Ok I brought a b grade gigabyte z77x ud3h from here but it has no io shield. Is it ok to use it without or do I need one? If so where can I get one from and would this one do? ****** Thanks matt
.Trying to find one that's the prob so u think I'd Defoe need one
Contact GB and tell them a sob story, who knows, might send you one for free. At the very least, should only cost a few quid.
