Hi folks,
I'm in the process of putting a new build together and I've noticed that with my Superflower 1000w psu I have 2 cables that say CPU1 and CPU2.
Now CPU1 has 2 heads with 4 pins on each while CPU2 has 8 pins.
Now my problem is this, eatx 12v2 is showing as having a 4 pin connector and eatxv12_1 is showing as 8 pins.
Am I ok to just put the power cable with 8 pins into the 8 pin connector or should I be connecting both the 4 pins together and the 8 pin one just half in the other?
Retarded I know but any help is appreciated.
