Urgent Help!! Re-adding DC Problem
1 Aug 2007
Hi all,
Im currently on a trip trying to fix a failed Domain Controller but cannot re-add it to the domain.
I get the message
"The following error occurred attempting to join the domain "domainname" The specfied user already exists.
I have removed the server from AD users and computers and replicated with the other dcs but still get this problem.
I then went a step further and followed the guide at http://technet.microsoft.com/en-us/library/cc816907(WS.10).aspx to remove the old metadata but still getting the same problem.
Any ideas?
Cheers all
Ahh,
Thanks for the prompt reply.
I was hoping I can use the original name because many applications are configured for that.
Is this not possible and likely I will need to rename it?
AD will probably still have the server's SID in it's database, you could try creating a new SID? (google NewSID)...
*Perhaps read up on the repurcussions of changing the SID first.
Done it!!! Thanks to those who replied!!
It also took a me going through DNS and removing any entries manualy and going through ADSI Edit and deleting any entries. I then finished up with a Force Replication and drunk tea for a hour. I tried one final time and bingo!! it worked.
