Hi,
I need to remove the heatsink on my http://www.supermicro.com/products/motherboard/atom/ich9/x7spa-hf-d525.cfm
It's overheating in the Supermicro 1U chassis and I think that the thermal paste might be an issue.
The pins that hold the heatsink in place are spring loaded and open wider when they have passed through the hole in the PCB itself.
I can not push the end of the pin together enough to make it pass back through the hole.
Should I use pliers? Is this the way to remove it?
I am installing a fan in the case as well to move some air over the heat sink as well but I think the thermal paste will help as well.
Any suggestions?
Thanks
Simpic
Any suggestions?
Thanks
Simpic
