Hi,
My system wont start, or rather it powers up to start then turns itself off. Its an overclockers system, several years old now with Q6600 overclocked, Ibit IP35 Pro XP Mobo, corsair 650 PSU and and upgraded fron the original MSI 6850 graphics card.
The mobo C1, then C3 then begis cycle up some numbers before reading 99 and shutting down. It tries to start up when power is delivered rather than waiting for the start button to be pressed. I took out the main bundle of leads that goes into the mobo and replaced and then it didn't try and start up immediately but when I pressed the start button it still did the same and shut down within a second. When the power is on there is a red light just above where the big set of leads plugs into the mobo but I admit i'm not sure if thats normal or not. I know almost nothing about hardware, and little about software really when it goes wrong.
Its a work computer and I had bucket loads to do today so am stressed.
It has doe this before and eventually turned on OK perhaps over a year ago, no idea why or if I did anything. Ive removed the power supply for a while etc to no avail. All the fans are moving freely and its not too dusty in there.
Any ideas.....
Nick
Any ideas.....
Nick
