urgent HELP what to do next win7 install
30 Dec 2007
Oxonfordshire
so i recieved my email about student upgrade, it didnt give me any option to download and save ONLY run, so after running its found my system is 64bit not 32bit which i already knew!
its now at this stage:
if i close it is that it and i cant download again to put to laptop instead of am i able to just use download link again as and when i feel?
The files will still exist on your PC once you close the window, do a search for setup.exe and you should find the expanded setup files, copy the files and away you go.
ok I found the folder.
also a while after recieved email from MS quoting
"(both 32-bit and 64-bit media are included in the Windows 7 package). If you want to install a version that doesn't match your current version, you can perform a custom installation of Windows 7. A custom installation doesn't keep any of your files, programs, or settings. For step-by-step instructions on how to perform a custom installation"
guess i will have to backup all files and do custom install.
