Make sure the ram, GPU, CPU etc are seated properly. It might even be worth taking all the parts out and putting them back in again. What the beep means, depends on the bios and how many beeps there are.
thanks il have a look.. its really ******* me off coz gotta do coursework for tomorrow!
There is an orange light on the mobo..as far as i know its normally green.
All my connections are ok.. the only thing i didnt do was plug in all the connectors from the top of the head like headphones etc and an extra 2 usb ports
try disabling raid options in the bios, your bios has reset during the transfer, you might want to go through it and check the options are all fine, nothing out of the usual
iv tried disabling all the raid controllers etc etc but still it hangs when i access my other drives.. as far as i know one of my drives is appearing as an IDE drive but they are all plugged into sata sockets.. this thing is going out my skylight window if i dont get this sorted within an hr!
think in the end it was the sata drives.. was talking to a guy in the local computer shop and he says gigabyte boards can cause sata nightmares.. next mobo will be an asus for sure!
