When i try to open my pc everything turns on the lights come up the fans start spinning and then after like half a second, it shuts down. i close the pc by pressing the power button for 5 secons and try to open again, and after about 10 trys i got it running again. i took out my 2nd gpu and the pc worked fine, i put it back on and it was ok for another 2 weeks, now it started to do the same thing again and i am worried it might be something to do with my psu or my 2nd gpu... any help? i bought these from ocuk about 3 months ago...
the psu is 1000HX Corsair
the gpu is Sapphire 4890 vapor-x
im so worried because i live abroad aswell and i dont know when i can get these items sent out back to the uk if there is anything wrong with them...
