URGENT, I think I've messed up big time
22 Nov 2010
Kettering
Hi all,
So I just got a 011 mini air, going to rebuild my PC into it, however, I have a 280 AIO that needs to go in the front.
Not only that, I'm trading my GPU for a zotac 3080 trinity, my concern is that I'm not sure if it's going to fit with a front mount aio and a set of fans, has anyone here got this setup or something similar that can advise?
Thanks
Well your 3080 trinity length according to google is 318mm long. Depending on your AIO thickness but lets go with 35mm thick for abit of leeway 280mm AIO with single side fans at 25mm thick so that gives 60mm +/-.
Add those together gives 378mm
The case apparently allows upto a max of 362mm but from what i've read it doesn't include the preinstalled fans upfront so you should be fine!
Tight but doable.
