Hey guys, i just got an antec Kuhler and upon installing it I did something stupid without even noticing.
Using a SG05 i was planning to screw the rad onto the front and then using the push pins of my separately bought fan tack it on the back.
So i thus used the 30mm screws or so provided and screwed through the unit, low and behold i notice i've punched a hole through the radiator lattice from front to back.... meaning they left active folds behind a non shielded screw hole, i.e. nothing stopping you from going right thru...
So have i forced a leak in my radiator ? (as of yet no water has even seeped out nvm gushed out (using it in a plastic wrap [not near cpu] ) ...
