URGENT! MS WORD EXPERTS
2 Mar 2006
Derby
I have a quick request is it possible in a word document to make different pages different colours.
E.g page 1-3 yellow, 4-8 blue, 9-13 green.
if so how?
How many pages are we talking about? If it's a low number just manually put in a box, colour it and send it behind the text. Repeat.
if so how?
Yes, you need a combination of section breaks for each block of different-coloured pages, and then Format, Document, Shading and change the colour there.
You might also want to have your Caps-lock key checked out, it seems a bit sticky ;)
must be the same problem you had when you registered for the forums ;) :D
Thanks for the replies guys
lol titles in capitals because it was/is urgent.
I'm not too brilliant with word so how do I put it into sections?
Insert > Break > Section break types
Do you have publisher? It'll be much easier in that. Or the openoffice equivalent will do.
