[URGENT] Need info on what to do!!
14 Jul 2011
I bought this Gfx card on 29th July last month.
But i think its starting to Artifact already! Kinda strange after only using it for 3weeks but i dont know what artifacts actually are. I will randomly see a square maybe abit smaller than 1cm x 1cm with a mash of colours inside it. Afew will pop-up at any time. My gpu is at 46-56 Celcius at idle, I havent overclocked it as it came OC'd.i have been using it on max settings on all games i play and on trackmania 2 i had 3D on which has bugged out and made most if not ALL my games in 3D including titles like COD 4/5 and even a online MMO i play. i have a HP Pavillion p6310uk with all stock parts except a " Cooler Master GX 450 '80 plus' power supply" with i bought from OcUk.
Do i call them and try and get a replacement or...?
Remove competitor link please and don't mention them :). Return it as faulty, contact their support team and you should get a replacement/refund no questions asked
You can't post links to that e-tailer or any similar as they are direct competitors with OcUK, there main business is the same.
edit, if you do need to post a link to the card, posting a link to the card on the manufacturers site is ok.
Yep it would be a good idea to remove the competitor link pal, its a big no no. But it does sound like it is artifacting to me. Get in contact for a refund/replacement.
