URGENT - need quick replys
7 Jul 2006
Liverpool.
I need a cardboardbox to put my tv in to i can send it of to be repaired / get a new one
( Its a Hyundai A321 )
I have tried everywhere :rolleyes:
Does enyone have eny suggestions where i will be able to get one ?
Thanks david 334
Asda
Tesco
Morrisons
Lidl
Aldi
Marks and Spencers
These are called 'Supermarkets' - they get stock in 'cardboard boxes' and will often give you one for 'free'.
*n
Thanks david 334
avforums, the q321 thread tbh
penski said:
Asda
Tesco
Morrisons
Lidl
Aldi
Marks and Spencers
*n
They all said no :(
David 334
Tried asking at your work? You may find your stores department or IT department may have boxes that suit your requirements
Try some kind of factory outlet if you have one close by.
All the Supermarkets I asked said no. My local Poundstretchers was happy enough to provide but didn't have boxes big enough. I used the local factory shop (ex-catalogue stuff) who had boxes big enough for me to put 4 alloy car wheels into.
Hope that helps.
IKEA sell flat pack cardboard boxes for people who are moving house and such but your sorted neways :)
david334 said:
They all said no :(
David 334
then you live in a dumb town :p
i used to have people come in and ask for boxes all the time - simple enough task to go outside and pick one up from the card bins.
i cant even begin to believe that ALL of the supermarkets where you live would have said no.
Don't know how the other supermarkets do it, but at Sainsbury's where I work all cardboard boxes are chucked into a bailer to be compacted and sent away to be recycled.
I suspect other supermarkets do the same. Even if they did retrieve a box from the bailer before it is compacted, odds are it will be torn or cut up anyway.
SiriusB
SiriusB
when i worked at sainsbury's from 16-17 we cut the boxes along the tape lines and put them into cages that got taken away by a truck.
same goes for tesco from 17-19.
then when i moved to a tesco express we didnt even put them in cages we just cut them and stacked them neatly.
