Hiya,
I have just built a brand new system, it has been working nearly perfectly for days with the only slight issue that the mobo doesnt recognise the 2nd gpu.
Anyway, I turned it off earlier, went to turn it on again and the damn thing will not power up. It will not go to post and simply starts the power up, kind of buzzes slightly and instantly powers down. The mobo shows a very brief red light next to the cpu (warning light for that I believe).
I have tried all the connections and I have cleared CMOS. I have no idea why it woul do this as it was working perfectly.
The spec is asus p8p67 pro (revised edition), 4890 gpu, [email protected] and 8gb muskin 1600 ram.
Any ideas before I take the cpu out and reinstall it??
Thanks,
Dave
Thanks,
Dave
