Urgent tmobile Vario II htc tytyn help
20 Oct 2002
Bromley
my phone fell off my lap earlier about 2 feet in its case, and there were no scratches or such like any where to be seen.
Now it wont vibrate or ring or play mp3's out of the loud speaker out the back which is obviously a big problem as the phone wont be heard when its ringing.
Im all insured BUT how do i flash back to t-mobiles standard rom as i have a a htc one on there.
unless of course any one knows how to get it working?
cheers but it wont work for what ever reason....
Anyone help me here as i wanna take the phone back tomorrow and i bet they are a bit funny when you dont have there software installed
tryed flashing it this way as well
http://forums.overclockers.co.uk/showpost.php?p=8955162&postcount=15
SPL-1.09 is my bootloader so i shouldnt be having problems should i?
Bootloader 1.09 DOES NOT allow downgrading of itself by means of flashing earlier ROMs. Once installed it is not possible to DOWNGRADE SPL 1.09 to older versions by regular means, you have to use SSPL.
^^ that could be how, but how do i get round it?
Please is there anyone that can help me so i can sort it today?
From reading im guessing it seems i need a cid unlocker?
dunno if this is right
right ive tryed flashing with the supercid unlocker so i "should" be able to flash with any rom?
now getting this error!
i was getting the same error when i updated mine the first time.
fixed it by running hardspl (v4 at the time) before the rom update
HTH
Steve
