- 10 Sep 2008
- Bangor, Northern Ireland
Hi Guys
I have a bit of a problem, i installed the new version of some software, and had to remove the previous version to do so. I need to revert to the old software as i dont have a software license for the new version but have to uninstall the new version before it will let me install it, but the software is not on the add/remove programs list and theres no option to uninstall it anywhere in the program files or in the start menu. Is there any other way to uninstall it??
Thanks for any help.
P.S its windows xp pro btw
