Urgent Which RAM Question - Help!
7 Oct 2009
I recently built a system using overclockers and advice from the forum. I've built the machine using the following RAM :
Patriot Sector 5 Viper II 4GB (2x2GB) PC3-12800 1600MHz Dual Channel + 3D Mark Vantage (PVV34G1600LLKB) £80.99
My motherboard is a gigabyte GA-MA785GT-UD3H
The problem is I now need to buy 4GB more but overclockers is out of stock and recommended I go for another make instead. Is this ok to do? If so which should I go for?
I need this quite urgently to get som software to run properly so any advice most appreciated :)
OK, I might buy 8 GB of completely new RAM then and sell the patriot ram on ebay.
Can anyone recommend me some ram?
cheers
