USB 2.0 problem HELP ASAP!
28 Jul 2003
Dundee
right i have a friends system -
AMD x2 3800
Asus a8n sli deluxe
2x512mb Ram
X800GTO PCI-E
now the problem is happened recently basically he cant use USB 2.0 and boot into windows, it basically freezes up, and this is without any USB 2.0/USB 1.1 devices plugged in. now i have tried a few tests etc and found that USB 1.1 works fine boots etc
now is there a program that i can test the I/O of the USB? or any other ideas?
(p.s. checked the memory and harddrive with WD diagnostics and memtest both came up with passes)
