usb 3.0 card reader
10 Dec 2010
sussex
hello ive a bit of a dilema i have a computer/mob that supports usb 3.0 and ive found a card reader that is usb 3.0 compatible ie pretec p240 will this be better than a good brand usb 2.0 ,the card im using is a sdhc extreme 8gb and will probably upgrade to extreme pro 45mbs/ will this be compatible with the card reader as ive already got a sandisk all in one which is not compatible with sdhc cards only sd ,and dont want to get caught out again ?or should i wait for a good brand to bring out a usb 3.0 card reader ie sandisk or lexar ,also heard that thunderbolt is coming at twice usb 3.0 speed ,but i suppose this is only relative to actual speed of the card write speeds ,also can some one recommend a usb 3.0 cable to complement a usb 3.0 card reader ive looked at the akasa ones on o/c website but looks like there are issues .
