USB 3.0 Internal Header Adapter for USB 2.0
If a mobo has only USB 2.0, and the case only has USB 3.0 (internal) is there an adapter available on the OcUK store?
depending on the case you could buy a new IO for it but your probably gnna spend the same money as a pcie card so if you have room you may as well do that.
I mean, a connector to convert USB 3.0 to USB 2.0? Like the one that comes with the Bit fenix raider connections !
