USB 3.0 not working
4 Feb 2007
Nuneaton, UK
I have the Asus P6X58D-e motherboard and a WD Mypassport usb 3 drive.
I have USB 3.0 enabled in the bios, also have all the NEC USB 3 drivers installed but when I plug my WD in I get nothing, the drive power light comes on but I get no sound from windows and can't see the drive.
What am I doing wrong?
Device manager looks all good too.
Thanks
Daft question, have you enable the NEC usb 3.0 controller plus other usb controllers in the BIOS?
Look at section 3.6.4 of the manual.
Sure itneeds the NEC drivers?
There are also Renesas drives, Windows 7 automatically installs the NEC one for my gigabyte,but I actually have to fight with it to install the correct ones!
After I got the latest drivers and firmware it now shows Renesas which is what NEC is called now.
Works with a different USB 3.0 drive, must be my WD drive or the cable.
Thanks for the help guys, glad it's not a motherboard fault.
Edit- not the cable.
The Drive is works so I don't care, just thought I'd make use of the speed.
