I want to upgrade to USB 3 just for the hell of it. I want to also hook up my USB2.0 antec300 front panel connectors onto USB 3.0 as well, so I can use USB 3 flash drives.
I'm thinking of buying a USB 3 PCI card, will it work as effectively as a native USb 3.0 motherboard, or will the performance be limited?
I'm planning on doing an editorial piece on it, and comparing the performance between a USB 3 vs USB 2 rig. So info will be helpful.
