usb 3.0 problem
11 Dec 2010
my motherboard doesnt support these but the case i have has these installed, is there any adaptors or anything i could use to make these work??
Does the cable for the USB 3.0 connectors from the case end in a male USB connector (like you'd find on a keyboard or mouse) or the 20 pin header connection like this:
And how many USB 3.0 ports are there on the case?
Mine is the same got a R3 case & zx68AP-D3
got a 20 header plug male is there a connector to go from this plug then into the I/O panel in the USB 3 port ?
