USB 3.0 problems
10 Jul 2010
I'm having a strange problem with my USB 3.0 ports. Sometimes I can plug a USB drive it and Windows 8.1 doesn't pick it up. I don't touch the drive, restart the computer, the USB drive flashes as normal and the BIOS picks up the drive when detecting USB devices - then when Windows loads, the device is then detected. All without me touching the drive at all. :confused:
Any pointers?
Secure boot enabled? If so do you also have options for not having USB enabled during boot?
Upgraded Windows, using correct chipset driver?
