Hi guys, I'm sorry if this has already been asked but I cant find the answer anywhere.
Basically I recently bought a new rig which consists of a Gigabyte P67A-UD4 and Lian Li case with 2x USB 3.0 external connectors.
The 'problem' is the USB case connectors are such that they can only be wired through the case, out of the back of the case, and plugged directly into the back of the motherboard.
I was wondering if there is some sort of adapter that the usb wired can be plugged into so that i can plug the in internally into the motherboard, freeing up the usb's on the back of the motherboard?
