USB 3.0 SATA Controller
14 Nov 2012
I've got 4 3.5 inch HDDs that I want to connect to PC. I don't want to install them inside the PC, I want to connect them via USB 3.0. There are a number of external enclosures that have SATA controllers in them that connect via USB 3.0 but, I would like to build my own enclosure to house them in so, I'm looking for a USB 3.0 SATA 6Gbps controller and power supply that doesn't come with an enclosure. Is anyone familiar with something like that?
If not, does anyone know of an external disk enclosure that I could remove the controller and power supply from?
You need to search for a 'bridge board' with the appropriate interfaces. Easy enough to find, but any supplier is likely to class as one of OcUK's competitors so you're on your own.
Thanks. I've been googling with no success but, searching for a USB SATA bridge board finds results like what I'm looking for.
I don't think OCUK sell them but, I guess suppliers that do could compete with OCUK on something else.
Thanks for the help!
