Hi guys,
my PC currently has a single on-board LAN connector which I use for my active Internet connection.
I have a second PC which I want to connect to my main PC. I was thinking of buying a PCI-E LAN Card but the problem is that I need all of the PCI-E lanes on my motherboard for GPUs.
I found they sell USB 3.0 to Gigabit Ethernet LAN Network adapters. Can I use one of those to connect my two computers while keep using the on-board LAN for Internet?
Would there be any conflicts between the two LANs?
If I were to use such adapter would everything else be the same as if I were using a PCI-E LAN card- would the second PC be recognized by my main PC as usual, would there be any sharing problems?
Would I sacrifice speed if I choose the adapter over an actual PCI-E LAN card?
Can I connect future PCs to my main PC by hooking up the adapter to my main PC, then hooking the LAN side of the adapter to a wireless router and from there connecting the other PCs?
Thank you kindly for all the help.
