USB 3.0 Transfer speeds
Permabanned
6 Sep 2011
Just bought a USB 3.0 usb and transferring 50gb of files over. 45 mins avereging at about 10mb per second.
I thought USB 3.0 is meant to be way faster than this? I understand that its limited to read speed (in which case my 2 SSD's are in RAID) ... so i dont know why its low. Am i missing something... google says
"USB 3.0, which can handle up to 5gbps (640MBps)"
'Just bought a USB 3.0 usb ' a usb what?
You'll be limited to the write speed of the usb device plus lower write speed if files are small (copying to usb).
But 10 MB/s is wrong not even usb2 speeds (eg a GB size file should easily copy at 40MB/s), are you copying or moving to the usb device or from the usb device?
Whats the rest of the system?
