USB 3 Header
22 Nov 2004
London
Hello,
I have just built a system using one of these beautiful cases: http://www.overclockers.co.uk/showproduct.php?prodid=CA-006-AD
...and the ASRock Extreme 3 Motherboard.
So far so good. However, the case has one of these USB cables and I can't find a corresponding connector on the motherboard:
http://i.imgur.com/egvkm.jpg
Being a bit of a perfectionist on this build, I didn't want 2 of the ports on top of the case being unusable, so I bought a USB card that I thought would do the trick, but it has a USB port facing internally, rather than a header.
Does anyone know how I can get the USB 3.0 cable connected to the system, perhaps through getting the internally-facing port to convert to a header?
Thanks!
I have also been looking at trying to find a USB 3 to USB header for similar purposes but there don't seem to be any as that USB 3 header standard has only very recently been made a standard and so few cases use it. Sorry.
No! Forget about work. We want it now.:D
Finally got round to doing this! Here you go!
The components:
The Kuhler - this was a pain in the proverbials to fit, but this video helped:
The completed build - you can see the offending USB3 header cable in there! :)
The build from behind the motherboard plate:
The only bit I'm struggling with is what to do with all the extra cables from the PSU. I think at some point, I'll tuck the rest behind the Mobo plate.
Overall, this was a very straighforward build, helped immensely by the excellent Anidees AI6 case. The real pain was the cooler, but I'm getting really low temps off it and it's really quiet.
