Can anyone recommend a USB 3 hub?
Bought a cheapish one and it's about as stable as a paranoid schizophrenic on crack. Seems to be isolated to 64 bit versions of windows.
I need a hub with 4+ USB3 ports all front facing.
The "tsunami" hub was the one I tried. Heard the icydock hub may have similar issues so i'm starting to run out of options a little.
Anyone running 64 bit with a USB 3 with front facing ports please gimme a make/model to shoot for
Edit: the one OcUK have for sale is the "Tsunami" hub (made by etron). I might have to give it another try then I guess.
