#1 | Link
uzeshan
New Member
BlackMagic Intensity Shuttle with USB3 PCIe card on HP Compaq 6000 Microtower.
Hi,
I have a HP Compaq 6000 Microtower PC and I have installed StarTech USB3 PCIe card to use BlackMagic Intensity Shuttle.
If I installed USB3 card on PCIe x1 slot then Black magic gives me an error message which says "Not Enough Bandwidth" but I installed the same card on PCIe x16 slot is works fine.
USB3 PCIe card is x1 card.
I checked PCIe info in more details with SiSoftware Sandra Lite which states PCIe speed is 2.5Gbps/5Gbps. I believe Mboard limited its bandwidth to halve. Any suggestions how can i change the speed or any other alternative methods.
Thanks
Zeshan
thanks
uzeshan
New Member
Hi,
Thanks
Zeshan
thanks
