Hi, there isn't much about this on the web, so I'm hoping some of you gurus can help me here. On my Motherboard, I went about installing a seperate card which has 2 USB ports on it. I opened the case to find there are 3 blue connectors to connect the USB wire. One being called "USB78" (which my front panel is connected to) , one being "USB910", and another being "USB1112". Now, are there any performance boosts between the 3? which one should I plug my card in which has 2 USB ports and Firewire Port, and which one should I put the front panel to? Thanks!
