USB bootable drive with image loader?
11 Jun 2003
Sheffield, UK
Just wondering if this is possible.
A USB bootable loader that then lets you mount and run a bootable ISO image from a choice of several.
Basically a way of having various OS install disk images on a single USB pen and pick which to load. Would be nice if it could also be capable of running various disk tools from a menu too (eg the norton ghost bootable loader, partition software etc).
I do a lot of "helping friends" with computers so just having a bunch of tools I can immediately get at regardless of the state of their operating system would be rather nice. Obviously being able to re-install whatever OS they have on their system running from an image on the USB drive would then be handy too.
I know you can have several live Linux distros on a USB drive. Getting Windows (of any variety) to run from USB is such a faf to not be worth it. Getting Vista and 7 to install from the same USB drive is doable, not sure how myself but some kind of white man magic with Linux would probably be involved
This might help out as a start
http://www.pendrivelinux.com/xboot-multiboot-iso-usb-creator/
Yeah, that's what I'm after. Not running from USB but mount and launch an image of the install disk. I'll check the link :)
Well it seems xboot is what microsoft are using for windows 7 and 8 test installs (if you go to download windows 8 preview it suggests downloading a "windows usb/dvd boot creator" thing that talks about windows 7 preview a lot). I assume it can do both. The MS utility (when complete) calls the USB drive "xboot" so we shall see.
Trying it now with my windows 7 disk image and the windows 8 preview image :D
I'm going for the same idea though. I have a tiny, tiny adapter that add just enough contacts and circuitry to turn a microsd card into a USB drive. It's fractionally smaller than a postage stamp and hangs off my keychain.
Having that able to fire up the win7/win8/whatever installers would be awesome :)
Does the Microsoft branded tool not format the drive before copying files though?
Yup, that one you linked seems to eventually want to do the same too :)
Edit: Failed installing to my sandisk cruzer but I think that's down to the funky U3 CD-rom drive the thing emulates when you plug it in. Trying a more vanilla one (and so far, so good).
No I mean that it want's to format before it copies any ISO, thus squashing any hope of making a multiboot drive. All bootable USB drive programs will want to do some kind of formatting initially
Yeah but the format is (I assume) to install it's own bootable menu loader thing. It can then boot ISO's once it's got it's loader into memory. I think that's how it's going to work.
xboot SEEMS to work but I can't get it to do anything once it's created. Trying YUMI.
As for yumi, it seems it can only do one windows based install. It converts the ISO back to files etc. Once done it removes the option to put another windows installer on the disk.
Try and use the "other ISO" option and while it will boot, it seems windows setup can't get at it's files properly.
Seems we will need to keep our windows installs on different sticks. If it's like win 7 then we can have a "all versions" installer though.
Hi,
I've got one of these and I wouldnt be without it.
Copy all your ISO's onto it and choose which one you want to boot from on the built in menu and then it emulates a DVD drive on boot up with the ISO mounted. I've got all my workstation, server and utils ISO's on it.
You can also use it as a hard disk.
You wont regret it, if you work in IT or do a lot of work repairing computers its a godsend.
I cant remember which firmware it comes with but on the website you download a firmware for what type of HD format your going to do. NTFS is probably best unless you especially need exfat.
Make a folder called _iso and copy yours ISO's into it. To use in ISO mode, hold the rocker switch up. To use in HD mode, hold the rocker switch down. I think holding rocker switch in middle position allows both to be active.
Any probs let me know.
Hi,
Yep, I think i'm gonna grab me one of those too. Very good spot. Even for other uses too, stick other images etc on there from the media library. I tend to have a small self powered external with me anyway so the iso mount feature is a definite plus :D
