1 Oct 2018 at 13:49 #1 Captain Captain Soldato Joined 1 Dec 2011 Posts 21,373 Location SW3 Can anyone recommend one please? Will be used for transferring files from a SD card and Micro SD card, would benefit from USB-C for faster transfer times between card and PC. Budget is whatever I need to spend.
10 Oct 2018 at 13:05 #2 Ace Modder Ace Modder Soldato Joined 8 Sep 2003 Posts 23,180 Location Was 150 yds from OCUK - now 0.5 mile; they moved https://www.macworld.com/article/32...t-speed-this-is-the-sd-card-reader-to-ge.html
11 Oct 2018 at 10:16 #3 EsaT EsaT Soldato Joined 6 Jun 2008 Posts 11,634 Location Finland Actually you won't find any SD cards capable to standard USB3's transfer speed. https://en.wikipedia.org/wiki/USB#Overview
24 May 2020 at 18:01 #4 ShiWarrior ShiWarrior Underboss Joined 20 Oct 2002 Posts 34,523 Location Oxfordshire / Bucks i use a sandisk usb 3 card reader, you could then use a USB3 > USC-C ?
29 May 2020 at 17:34 #5 Snapshot Snapshot Soldato Joined 11 Oct 2006 Posts 5,271 Location Wiltshire Ace Modder said: https://www.macworld.com/article/32...t-speed-this-is-the-sd-card-reader-to-ge.html Click to expand... I have something very similar from Sandisk but the plug is on the end of a short cable rather than a stalk. The model number SDDR-409.
