I'm now looking at sourcing components for building a new desktop station (Most probably Ryzen 3 based).
Ideally what I am looking for in a case is as follows:
- Most importantly, Good airflow.
- I currently have a Vega 56 pulse card which is a tight fit in my current case but may update card down the line so a bit extra space would be good.
- Ideally under £200
- Have a USB-C on the front panel.
- Enough height for an aftermarket air cooler such as the Noctua or Dark rock coolers.
- No interest in RGB at all.
My ideal case would be the Meshify-C with the updated I/O USB-C port.
Just set up a watercooling loop and 2x 360 radiators in mine zit was a joy to work with the case and it looks very clean and understated from the outside.
