usb-c gen 2 hub - oculus
17 Aug 2005
Gloucester, UK
Been reading a few posts on reddit that suggests the oculus can run 2 sensors, rift (incl hdmi) from 1 hub in a usb c gen 2 port.
Anyone tried this on here? if so what hub do you currently use? . would be nice to have all in 1 port tbh.
many thanks
It's probably doable. The headset doesn't need much bandwidth just power. It all depends on the motherboard. If the USB C has it's own controller then no problem, if the controller also runs the USB 3 ports, then there be might be a problem if you have other devices plugged in using bandwidth.
