USB C Power for Intel NUC?
28 Sep 2008
Britain
Does anyone happen to know of any USB C power cables that could power an Intel NUC 5i5 through it's normal power supply port? I'm aware that I would still need to cables (one for power and one for monitor output) but if I can get away with all those cables being managed within the monitor (so only the monitor is physically connected to a power socket) that would be ideal.
Thanks
EDIT, guessing something like this is what I need:
https://www.amazon.co.uk/Cablecc-Fe...ocphy=9045705&hvtargid=pla-947128267187&psc=1
Sorry not quite the answer you wanted but I used this for my home setup:
https://www.amazon.co.uk/gp/product/B06ZY1ZJDQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I had to get a proper USB-C charger to feed into the adaptor though, rather than re-use the existing/current one.
Yeah that's kinda the other way around. Effectively the monitor is the hub, except it will be useless in this scenario because It won't be plugged into a USB port on the NUC. This NUC doesn't have usb C, but does have DP and HDMI so I can carry sound and video from there. I just wanted a neater way to power the NUC from the monitors USB-C PD port, which it looks like I can do. Test is later when the part arrives.
Then I can just plug the monitor into the wall, USB-C cable to the NUC and HDMI back to the monitor all whilst having the NUC installed on the offset VESA mount on the back of the monitor.
