USB Cable Broke
29 Dec 2009
Beijing
For some reason my USB cables end up wobbling about on my Nexus 7. I now got to put pressure on the cable to make it charge. I thought it was the port but I tried some other cables and they fit as snug as a bug in a rug. 2 have gone like this.
Anyone had this happen? Can I fix the cable?
Use the end of a needle, stick it in from the front (bit that would go into the usb port) under the tab and gently raise it a bit, then use some compressed air or a good blow to clean out the port on the Nexus as well, should be good as new.
