USB Cable needed - A(m) - A(m)
14 Dec 2003
Edinburgh
I need a male A to male A USB cable, have had a look around and all I can find is the Belkin Windows Vista Easy Transfer Cable and it costs £17! is this JUST a cable or does it have something else built in? Is there something complicated about a male A to male A USB cable that makes it cost this much when a male to female can be had for a couple of quid or is it just because no one wants them?
can someone give me a product name for a cheaper one or am I just going to have to splash out?
thanks in advance
The Belkin cable comes with software to allow transfer of data between two PCs. It is effectively a peer to peer network cable.
You should be able to find an A-A cable with some web searching.
I think it also has some electronics in it, iirc a straight connection between 2 PC's could result in damage to them.
