Hmm interesting, I doubt there is a loss of power in the cable.
Are you sure its not just a dogi cable? I don't think length would come into it. Having said that perhaps the HDD is drawing too much power (it is quite common ) and requires a powered hub.
5m is the maximum length for USB. More than that, and you need repeaters.
I have a 5m USB extension cable with a repeater on the end. Can plug anything into it and it's fine. Which leads me to the conclusion sid came to: dodgy cable/port?
USB hdds are very close to that (+ some converting chip to convert IDE to USB will use some power as well), so it might just not have enough juice tbh,
Where are you plugging it into? My Seagate external HD won't work off the front panel USBs or off my monitor's ports, it has to be plugged directly into the motherboard.
