http://www.truecrypt.org/downloads.php
Free and one of the best out there. Creates a virtual partition on any drive you like and encrypts the free space in it as well, allows you to put another encrypted partition inside that as well for plausible deniability. You can use a combination of 3 different encryption algorithms. Its on the fly, so as long as you have the program in the taskbar anything you put into the partition will automatically be encrypted.
